1 - 3 of 3 Posts
Is there a way to exchange the front grills without removing the clam? If not I guess its a good time to do the ac improvements. But any way to change them without clam removal?
The center one just pops out, the 2 sides are held in with a screw. You can remove the headlights and there is a small hole for drainage. I drilled mine out at little bigger so I could use a screw driver. Leaving in the screw so I could put another set back in.
Thank you! I was hoping to save the clam off for the winter.
1 - 3 of 3 Posts
