1 - 7 of 7 Posts
I am guilty of messing with this more than I ever should have. My current view is that the same compound all round is just fine. I would perhaps recommend a higher friction compound in the rear if you still have OEM callipers. For street use, none of this matters much.
Sent from my Pixel 4 using Tapatalk
Less is Better
Which model are you asking about or are you asking in general? If the brake bias is set up by the manufacturer correctly, the compound should be kept equal front and rear. And it's usually set up correctly by the manufacturer. Some would argue the Elise isn't set up correctly, but that's not my experience (and ABS hides a lot of issues).
thanks for your messages.
at the moment I have on front: FERODO DS.UNO
but on rear i don't konw how I can put.
FERODO DS.UNO are not still available.
so I can choose between:
FERODO DS.2500?
or
FERODO DS1.11?
you can see here
more info about FERODO pads
FERODO DS.2500?
or
FERODO DS1.11?
you can see here
I have dsuno in front and ds 1.11 in rear and this configuration is not so good. I prefer better pad in rear. I had ealier ds 1.11 in rear and ds 2500 in front and balance was better. I will prefer to set ds 1.11 in front and ds 3.12 in rear.
1 - 7 of 7 Posts
