Folks, 2 quick questions. Tried to search but found no relevant information.
BF Goodrich Braided Hoses - The 4 braided hoses are identical, there is no difference with front or rear, which means, it doesn't matter which hose goes where, while the front has slightly more length to compensate for the ABS module, correct?
Front Rotors For Rear Use - Front rotors are bigger than the rear rotors, are the hub specifications the same? Has anymore moved the front rotors to rear and used them for improved braking?
