re: Clicking noise from front wheel
Did You re-torque the wheel nuts?
Anton
Anton
Went to the track the other day for a little fun and a new problem started occurring mid-day. In a hard right hand turn the left front wheel developed what I can only describe as a click, although it wasn't necessarily audible (too noisy with wind and engine rev'd). Anyway, it could definitely be felt in my seat and the steering wheel, and it varied with speed. I checked for rocks and played with the air pressure a little as the wear pattern looked like the tires were slightly over inflated. Went back out and it continued under hard cornering so I called it a day and switched to my MR2 for the rest of day, probably a good thing as I had a backwards off when a thunderstorm came through and turned the track into a lake :facepalm.
I've read through the threads regarding audible clicking in the rear, doesn't sound like the same thing as it only occurs under high lateral load. I'm thinking it's the wheel bearing, haven't had a chance to put in on the lift to look it over yet. Has anyone run into a similar problem or have had to replace their front hubs yet?
