I have 50 1QT Bottles and a few 5L ASMOIL
Local Pickup is welcome for those in ATL Area
7.95 Plus Shipping
Detail info AMSOIL Synthetic Motor Oil and Engine Oil
Product Description
AMSOIL European Car Formula 100% Synthetic 5W-40 Motor Oil (AFL) is specially formulated for the lubrication needs of modern European gasoline and diesel cars and light trucks. Formulated with advanced AMSOIL synthetic base stocks, premium additives and a 5W-40 viscosity rating, AMSOIL AFL is the preferred oil for virtually all European automobiles, especially turbo charged models. It is one of the only oils in North America to be recommended for the latest specifications of all three major European automakers - Volkswagen (Audi), BMW and Mercedes-Benz and the latest North American API specification. AMSOIL AFL is highly versatile for multiple applications.
AMSOIL, the leader in automotive synthetic lubrication, produced the world's first API qualified synthetic motor oil in 1972. Trust the extensive experience of AMSOIL The First in Synthetics® to do the best job protecting your engine.
Maximum Engine Protection
AMSOIL 100% Synthetic European Car Formula contains high quality anti-wear additives and surpasses the tough ACEA oil specifications for high temperature/high shear viscosity. It provides outstanding protection in high RPM, hot running engines and delivers dependable long-term performance for the extended drain intervals set by European automakers.
Superior Engine Cleanliness
The excellent oxidation stability, heat resistance and detergency properties of AMSOIL Synthetic European Car Formula keep engines clean. It is specially designed to prevent sludge and varnish deposits for reduced oil consumption, extended engine life and maximum overall performance.
Minimizes Exhaust Emissions
AMSOIL European Car Formula is designed for newer vehicle emission control systems. It meets current industry and vehicle manufacturer requirements for long life protection of gasoline vehicle catalytic converters and diesel particulate filters (DPF).
All Season Performance
The broad 5W-40 viscosity rating, low volatility (burn-off) and wax free nature of AMSOIL Synthetic European Car Formula make it excellent for hot and cold temperatures. Engine wear is reduced, oil thickening is controlled and vehicles start easier in cold temperatures.
APPLICATION
AMSOIL 100% Synthetic European Car Formula is formulated to surpass the most demanding European specifications. It is recommended for European and North American gasoline or diesel vehicles requiring any of the following worldwide specifications:
•API SM/CF
•ACEA C3-04
•ACEA A3/B3-04
•ACEA A3/B4-04
•ACEA C3
•BMW LL-04
•Mercedes Benz 229.31, 229.51
•Porsche
•Saab
•Volvo
•Volkswagen 502.00, 505.00, 505.01
•DaimlerChrysler MS-10725
Service Life
Recommended for the extended drain intervals established by the vehicle manufacturer or extend based on oil analysis. Change oil filter at time of oil change.
Mixing AMSOIL
AMSOIL AFL is compatible with conventional and synthetic motor oils. Mixing AMSOIL motor oils with other oils, however, will shorten the life expectancy and reduce the performance benefits. AMSOIL does not support extended drain intervals where oils have been mixed. Aftermarket oil additives are not recommended for use with AMSOIL motor oils.
7.95 Plus Shipping
Product Description
APPLICATION
•API SM/CF
•ACEA C3-04
•ACEA A3/B3-04
•ACEA A3/B4-04
•ACEA C3
•BMW LL-04
•Porsche
•Saab
•Volvo
Service Life
Mixing AMSOIL
