1 - 5 of 5 Posts
A new year makes it time to finally cut the second Lotus loose. Just take a look at buying a base Lotus and add in the Motec gear and Race Spec Harness and your getting everything else for next to nothing. I'm selling for the best offer over $49,900 or the first one to come up with $54,900
I truly believe this car is worth at least $10,000 more than the listed price. You'd be over $100k to try replicating this car.
550whp 2005 Lotus Elise Build Details
K24/20 (K24 Block w/ K20 Head)
JE Asymmetrical Pistons 9.0/1 CR 89mm, Brian Crower 625 +Rods
Stainless steel Valves, Dual Valve springs, Titanium retainers, Valve Locks and Custom Billet Camshafts
Aviaid Dry Sump oil system
Skunk 2 intake, Drive by wire throttle body
Air to Water intercooler
Precision 6062 Gen 2 Turbo, Tial wastegate and blow off valve
Bosch Motorsport 1,650CC Injectors
Ghostworks Transmission Build with Gear X Drag 2 Gears and M Factory LSD
ACT XTSS clutch with XACT Streetlite Flywheel
Alitech Shifter
Motec M400 Standalone ECU & CDL Digital Dash with logging enabled
Traction Control, Launch Control, Gear Detection, Speedometer & Calculated Fuel Level.
Tuned with GM flex fuel sensor. Boost Varies based on Ethanol Content. HP is just under 400whp on pump gas.
Has selector switch for on the fly boost and traction control level change. Currently selections range from 400-550whp There is a ton more room left for more power if you want it. I've had well over 600whp but didn't like the drivability of the 3 puck clutch. The current clutch held to around 620 whp but it was dropped back down to the 550whp be safe. Max Dyno numbers are with around 20lbs of boost with 400whp on waste gate springs.
Race spec wiring harness
AP Racing Big Brake Kit
Front Brakes relocated to rear plus original rears maintained for emergency brake
Safety Devices 6 point Removable Roll Cage
Nitron GT3 Triple Adjustable Shocks with 525/650 Springs
Bushing Replacement kit
Sector 111 RTD Brace
Sector 111 V2 arms and shims
APR GTC-200 Adjustable wing
GUT Sport Spoiler and APR Carbon Fiber Splitter
ReVerie Carbon Fiber side scoops
Difflow 5 element diffuser
Bogart Custom 3 Piece Wheels 18x11 Rears and 15x10 Fronts
285/30/18 BFG Rival Rear Tires
245/40/15 BGR Rival Front Tires
Pro Alloy Fuel Tank
Full Body Off Repaint in Satin White
Kenwood Bluetooth amp
1256833
1256834
1256835
1256836
1256837
1256838
1256839
1256840
1256841
1256842
I could get the price down to $44,900 if I switched the Shifter, Shocks and Seats back to stock.
Sale Pending.
Everything is being sold with Car with Exception of the Rear wing which will be available for sale after the car leaves in a few weeks.
1 - 5 of 5 Posts
