1 - 3 of 3 Posts
I know this is out of a celica GTS but good stuff 4 sale :p.
FOR SALE:
Complete Engine Setup 2000 Celica GTS 2zz-ge 6sp setup with 70,xxx miles on it.
Everything was removed 5 months ago. The engine was running strong and shifting perfect before the wreck.
This swap has everything you need but missing the air cleaner box and the front motor mount.
Everything else is there (ECU and box, wiring, injectors, axles, engine, tranny, altenator, starter, a/c compressor, and also the shifter with linkages!)
$3000 . Also i have other celica stuff as well that can go with it. I am done with the celica scene. Will ship if you arrange all shipping.
Also for sale....
C60 6sp Tranny. Has 58,xxx Miles on it. Pulled it out of my friends gts. all gears shifted before pulled.
$900 Will ship if you arrange all shipping.
ACT Extreme Clutch Kit. Slightly used (less thank 1500 miles) (pressure plate, clutch pad, throwout bearing)
$120 plus s/h
TRD stock clutch kit with less than 3k miles. (in this kit, clutch pad and pressure plate)
$100 plus s/h
$75 plus s/h for a flywheel that doesn't show any hot spots.
UPDATE
Bare BlocK Sold.
I have had emails about shipping the swap setup. I have decided to lower the price so shipping will compensate.
I will take $3,000 for the complete swap and will throw in some celica stuff that is laying around here. When your interested in the motor i will list wha i have. Such as a cut in 2 mid pipe, plastic pieces, interior pieces, suspension pieces, brake parts etc..
I still have the C60 and will throw in the flywheel and a clutch kit whoever purchases it.
Thanks dudes
Kel
· Vendor
Do you have the timing chain cover and timing chain side motor mount? Starter?
Thanks.
1 - 3 of 3 Posts
