I have a Used MXL Pista Data logger Dash.
Comes with Display Dash, CAN/Serial (RS-232) Main Harness, USB download cable, water/oil Sensor, Magnetic speed sensor, Infrared lap time transmitter / Receiver, Aim Can Data Hub, Aim Memory key, Extra 4 pin push on type patch cables. It also includes a brand new never used LCU-ONE Wide Band Lambda Controller with unopened wide band Bosch LSU 4.9 probe. I will also include instrument binnacle wrapped in black suede that was modify to fit the Dash,"Will need to be glued back together".
More info:
MXL Pista
Features
• Wide, brilliant display (5.5") with backlight standard
• RPM displayed by number and graphic curve
• Configurable RPM scaling
• 1 RPM input
• Internal G sensor / accelerometer
• 1 Speed input
• 8 analog input channels: temperatures, pressures, potentiometers, Lambda sond, onboard and custom sensors
• Samplng rates: digital inputs up to 50 Hz, analog thermocouple up to 100 hz, analog potentiometer up to 500 Hz
• Gear number calculated or sampled from on-board sensor
• 10 shift light LED's - green - yellow - red
• 6 freely configurable alarm LED's for min/max alarm
• Fast USB data download to your PC for analysis with Race Studio software
• Infrared lap receiver and infra red lap transmitter
• Lap times - split times
• Configurable number of split times
• 8 MB of non-volatile memory
• Built in clock and calendar for test management
• Internal data acquisition system
• Total and partial odometer (with reset)
• Rugged, water resistant, lightweight aluminum chassis
• CAN/Serial (RS-232) interface connects to many ECU's
Specifications
• Dimensions: 6.85" wide x 4.33" (174 x 110 mm)
• Display dimensions: 5.5" x 2.6" (140 x 67 mm)
• External 9-15 V power supply
• 8 MB non-volatile internal memory
More info:
AiM Sports - The World Leader in Data Acquisition
Photos / Video
https://www.dropbox.com/sh/1lmgbn38v5rxciy/qMBbOInpT0
Paid Close to $3000 new
Price $1800usd :up:
Buyer pays Paypal / Shipping fees
