1 - 9 of 9 Posts
OK, so I'm an idiot. I ordered this figuring I would put it in before the 1st autocross/race. Well, here I am selling it on LT. WHY? You ask. Because the S-240 comes with an adjustable sway bar already set to the middle position (stiffer than normal). All I did was move it in 2 more positions and sha-bang the car handles even better.
Point of interest for you S-240 owners. The S-240 sway bar has a different mounting system completely. You can even get to the bolts on the S-240.
The bar is BRAND NEW and never used. 1st $290.00 takes it plus shipping. Remember, this is the more expensive SCCA Hardcore sway bar.
Vendor
WILL THIS FIT A REGULAR ELISE OR JUST THE S240?
It will fit both. for the S240 you use the stock bushings and use the poly bushings included as spacers.
Sorry to disagree, but the S-240 does not have normal bushings like the Elise and Exige. It uses an aluminum clamp that's machined to fit the slightly smaller diameter bar. I'll have to take a picture and send it to you. I'm sure it will fit the small bar but not the SCCA Bar
At any rate, sway bar for sale! Brand new.
Vendor
I stand corrected. You're right, the SCCA bar is bigger OD. It will work on all the other Elise and Exiges.
Discussion Starter · #8 ·
Bump - Still available
Brand new in box... Fix Elise, Exige & Exige S - Will not fit the S-240...
A must for the serious race crowd...
1 - 9 of 9 Posts
