1 - 10 of 10 Posts
hello
FS: CRD mount (sold)
I have a crd mount for sale, the same as: CRDmount
I got it new. Mounted it once on my bar to try it out. I was not happy with the camera position and decided to go a different direction. All pieces originally available with the kit are included (see attached photo). The condition is as good as new.
SOLD
hello
Discussion Starter · #3 · (Edited)
I tested it on my bar from sector111, so I cannot be sure about others. Having said that, the two round pieces are adjustable using two screws and there is also a foam sticky pad usable for different bars with smaller diameter. So I would imagine if the bar is relatively similar in diameter, it should fit. if it is too thick, I could see a problem.
Anyone knows the diameter of the stock bar?
if it'll fit the factory bar i'll take it
The CRDmount will not fit on our Race Harness Bar or on the Lotus Motorsport Harness Bar.
as per sector111 link he provided
hello
Can you measure the diameter for the bar you are interested in mounting it on?
The two inside rings will fit perfectly a bar that is 1.25" diameter. Anything less than that and the supplied foam pads can be used. Anything wider and the screws can be adjusted to fit but it will not be a perfect round fit.
Disingenuous Minion
it says on the Sector 111 listing linked in the OP that it doesn't fit the Lotus harness bar...
hello
Discussion Starter · #8 · (Edited)
I was asked by a couple of people on shipping rates. To simplify things, I can do SOLD shipped anywhere in the continental US by UPS ground. Ping me about faster options or locations outside the continental US.
I'll take it. PM sent
1 - 10 of 10 Posts
