For Sale
Custom Trailer hitch for Elise or Exige
I sold my car so I no longer need this. I had this made up by a local fabricator. It is mostly1.5" steel tubing. Like most other Elise/Exige hitches it requires 2 holes drilled in the lower rear steel frame cross member (same piece that the larger rear diffuser bolts are mounted to). The front bolts to the existing threaded holes by the diffuser air ducts.
I used it to pull the small 4x4 harbor freight trailer with 4 wheels + tool box to autox.
The nice thing about this hitch is that you can easily take out the 2 hitch pins and remove the back half for normal daily driving, and the remaining part on the underside is not real visible.
Includes all hardware needed to mount to the car.
Asking $350 shipped in the US
Paypal is fine if you have a verified account
call/txt: five eight five - seven seven one - seven three one eight
Email: z06fun at yahoo dot com
Mounted on the car (note the piece of sheet metal is just a cheap exhaust shield I added):
Mounted on the car with rear half removed:
In use:
In use:
