For Sale car # 101 Lotus Spec Elise
2005 Elise, perfect running car with no issues. Many podium finishes and 2nd place over all for the 2013 series.
Car has a title but is currently not registered
Tig welded VSA cage
Lexan front and rear windows
Carbon Technocraft or Lotus Sport Recaro seat
Schroth Enduro 6pt harness
Lifeline electric fire system
Electrical and mechanical battery disconnect switches
Sparco steering wheel with quick release
Aim Sports G dash with full data logging, fuel level, throttle position and GPS speed
BOE oil pan
BOE floating rotors
Performance Friction pads
Machined Uprights
Nitron 46mm single adjustable shocks with lightweight Swift springs
IMRP Monoball Spherical bearing suspension bushings
Sector 111 front and rear clams
Single layer roof
IMRP rear toe link arms with 5/8 outer heims
IMRP Spec diffuser that DOES NOT attach to the clam (makes removal of the rear clam easier and will not crack the rear clam if contact is made with the diffuser.
Coast Fab muffler WITH Decat
Radium Catchcans
Clutchmasters Clutch (just installed)
All Torco fluids
Many upgrades to the complete shifter assembly (This car does not shift like a normal Lotus)
Side mount Setrab oil cooler
Ceramic coated exhaust
Simplified engine bay
Hardwired transponder
Brent Bauman radiator / cooling system
Brent Bauman Kevlar fuel cell (no fuel starve and 15 gal capacity)
2 sets of wheels, spare diffuser
Billet Innovative motor mounts 95A
Quick release rear engine cover
Technocraft Carbon access panels with quick latch buttons
Matte grey wrap (holds up better then paint and easier to fix)
Window net
Also available 20 Ft Featherlite enclosed trailer. Purchased new this year, LED lighting inside and out. 60gal fuel system with retractable fuel reel, 110V power system, AC, front workbench and cabinets. Syn. winch with front and rear controls. Race ramps. Anderson Hitch sway/ weight dist. hitch.12v battery and solar panel charging system. Upgraded axles with 16in tires. Spare tire. $20K OBO
Located in So Cal
Tim 714-397-3O31
$31K OBO(parts can be removed for lower pricing)
Tig welded VSA cage
BOE oil pan
BOE floating rotors
Machined Uprights
Single layer roof
Radium Catchcans
All Torco fluids
Window net
Located in So Cal
Tim 714-397-3O31
