1 - 7 of 7 Posts
Innova 3100
Phenomenal reviews on Amazon
In perfect condition working-wise and cosmetically.
What you are buying:
3100 Diagnostic Tool
OBD2 16-pin DLC cable
Repair Solutions software
USB cable
user manual
NO BOX
Has been purchased for $130 (receipt is stapled to the manual).
It is now $99 on Amazon.
Yours for ONLY $75 shipped...OBO
I don't see why not. Is there anything different about the 2010? I have been reading a 2007 with it.
Noob question, what would it be able to tell you? Can you edit the code? How is this different than an OBD2 cable that attaches to your laptop as this is much cheaper alternative.
It will tell you the code, what is means, freeze frame data if available from the ECU which gives you some more info at the time the code was thrown. I have not used the OBD2 cable. I suppose there, you need to have a software on the laptop to translate.
One advantage I see for this is that it is much more portable than a laptop and you can leave it in the boot if necessary.
1 - 7 of 7 Posts
