For sale, in Bellingham, WA is my heavily modified 2003 Volkswagen GTI. It is show quality and has won numerous trophies.
117k miles on the body and 5k on the engine. Oil changes with Lubro moly 5w-40 every 3 – 3.5k since I have owned the car. Engine runs like a well-oiled rocket clock. Receipts available for engine internals upon request.
Paint sprayed on hood, fenders, doors, roof, rear quarters March 2014. Paint on front and rear bumpers and mirror caps sprayed summer 2013.
Head and block were tanked / decked / cylinder walls honed by Machine Works of Lynden, WA. Internals installed by friends and myself.
Paint / body shaving / frame notch / Accuair level sensor install all done by RCR Autobody of Bellingham, WA.
Bagyard bags / manifold / dampners / air compressors / management wiring / battery relocation all done by friends and myself.
Hardlines by Swoops of NY.
Hardwood inlay by Greg Aines of Greg Aines Furniture.
Engine
180 DIN-PS / 132 kW 1.8L Turbo – AWP bottom end, AEB head
Integrated Engineering 20mm H-beam rods
CP 9.5:1 pistons
Calico bearings
Double dowel pinned crank
ARP head studs, rod bolts, crank bolt
Supertech Inconel exhaust valves
Transitional phenolic intake manifold spacer
Integrated Engineering manual timing system
Gates Kevlar belt
Metal impeller water pump
(timing refresh and water pump installed at time of engine rebuild)
Deleted N249/N112/EVAP/SAI – EVAP parts are available if you wish to reinstall
42 Draft Designs stealth recirc catch system w/10-AN stainless lines
Valve cover fins milled flat and VC powder coated wrinkle black
Integrated Engineering press fit 10-AN breather adaptor in VC, and Integrated Engineering 10-AN crank case breather adaptor installed
BMI Flow stack intake w/K&N Filter
APR R1 diverter valve
ECS stage 1 clutch
Odyssey battery relocated to spare tire well in an anchored bracket and battery kill switch
BFI Dogbone bushings
Integrated Engineering billet shifter bracket bushings
Exhaust
42 Draft Designs 3” turbo back, twin double wall stainless tips, high flow cat
Software
Unitronic Stage 2 w/ full emissions deletes
Suspension
Bag Yard classic single bellows front and rear bags. Stainless leader lines in fronts
Bilstein dampners
Accuair E-Level management with touch pad controller
Custom Hardlines
Real bamboo false floor (not laminate) with real mahogany inlay
New strut tower bushings
Have new ball joints but they will need to be installed
Wheels/Tires
Keskin KT4, 17x8, 5x100 ET30 – lips polished by Meister Werks
Toyo 4plus 205-40, lots of life
Body
Jetta front end swap
Fully shaved hatch, hood notch, side rub strips, and front plate holes (hatch pops by remote and driver’s door button)
4Motion front lip
Two tone Tornado Red / Black paint
Go Mini Go tow hook license plate bracket
Badgeless 4 bar grill
Euro Image tuning rear wiper delete plug, black gloss powder coat
Interior
Burberry rep plaid head liner, A, B and C pillars
R32 Black upper plastics, sun visors, upper hatch trim
SEAT Arosa climate and light controls
Leather Corbeau A4 seats
Schroth quick fit 4 point harnesses
New Lupo shift knob and shift boot
Audi TT pedals
MKVI flat bottom GTI steering wheel – air bag wired correctly, MFSW buttons light up but do not control stereo
New ashtray sliding cover, cup holder lid, driver’s door pull, passengers door pull and cover
New South Performance indigo boost gauge in single pod steering column mount
LED dome and map lights
Notes
Air bag light is on since driver’s side seat belt buckle resistance too high; passenger’s side module resistance too low.
Small paint chip on passenger side bumper corner where it meets the fender (may be fixed soon); some scuffs on clear coat on mirror caps; a couple very light scuffs on rear bumper.
Scuffs on glove box plastic, passenger’s side foot vent cover, and parcel shelf side plastics.
Several small (but filled) chips in the windshield; no cracks. Small chip in passenger’s rear window.
Included items
HEX+CAN VAGCOM cable.
Newish Thule roof racks with locks and extra keys
EVAP parts (if you care and your Prius is the boss of you)
Spare tire
OEM tool kit, Audi first aid kit
Wheel center cap tools
New ball joints
Spare valve cover gasket
Parts for coolant ball delete: Moroso radiator filler neck, pressure cap, polished stainless surge tank, fittings and hose for reroute.
There is likely more stuff but I cannot remember it offhand.
$13,000 - Note that mileage will slightly increase if not sold as it attends more shows. The car will be at Waterwerks On the Green in Bend, WA. at the end of the month should you be located in WA and are unable to make the trip to Bellingham.
More photos can be taken on request and it can be viewed most weekdays after 6.
Please PM for my contact information.
Title in hand.
Engine
CP 9.5:1 pistons
Calico bearings
Gates Kevlar belt
ECS stage 1 clutch
Exhaust
Software
Suspension
Bilstein dampners
Custom Hardlines
Wheels/Tires
Body
4Motion front lip
Interior
Audi TT pedals
Notes
Included items
Spare tire
New ball joints
Title in hand.
