no PM has arrived
Sent againno PM has arrived
The advantage to the 15" front is that you can run the car lower without running into bump steer issues with the stock steering rack. I have a set of these in 15/16 and they are incredible. They are so light that the car actually accelerates better and stops better. Just think of big flywheels on your car with the stock wheels. They look cool, sure, but there is a real performance gain from taking this unsprung weight off the car.Guys please read my sale description carefully. Fronts are 15”. Rears are 17”.
I had a member bought them then I had to refund because he thought the fronts were 16”.
If you are looking for one of the lightest wheel configurations for the track then look no further. The fronts are only 9 lbs each. And the rears are 14 lbs each. They don’t come much lighter than that. And they’re forged from a well known company.
They’re still available guys.
Thanks mate! Seriously though, someone buy these.The advantage to the 15" front is that you can run the car lower without running into bump steer issues with the stock steering rack. I have a set of these in 15/16 and they are incredible. They are so light that the car actually accelerates better and stops better. Just think of big flywheels on your car with the stock wheels. They look cool, sure, but there is a real performance gain from taking this unsprung weight off the car.
Remember that rotational inertia is 4.4 pounds per one pound of grounded (sprung) inertia. So, if these wheels cut, conservatively 15 pounds off, then the effect on the car as far as acceleration will be like removing 66 pounds or in a normally aspirated car, adding 6.6 HP to a 190HP engine.
SOMEBODY BUY THESE WHEELS!! You won't regret it.
:wink2::up:
. How easy is it to tell the color difference?Bump. Make me an offer guys.
It’s kind of like after a couple of driving sessions where the front wheels are slightly darker than the rears due to more brake dust. That’s the best analogy that I can think of.. How easy is it to tell the color difference?
I appreciate your help. Thanks.Just trying to help and promote these nice wheels. Oh well, good luck with the sale.
