Just ordered the mounting kit. They are out of the factory looking washers though. Someone is selling an NCI kit with scoops in the fs section.has anyone used these? how is the fit on them? I am going to use them on my CO elise.
any info or pics would be appreciated.
I am looking at the FTP scoops with FTP mounting kit or there is another set on here for sale that has an NCI mounting kit and goes for a little more $.
FTP Lotus Exige Glossy Carbon Fiber Side Scoops :: Exterior Body Panels :: Interior/Exterior :: Lotus Elise & Exige :: Fast Toys Performance
So, yours went smoothly with this kit, but you had to shave some down on someone else's? That would be disappointing.I have them on my car. I installed Darrin's and the mounting kit was terrible. It was strange because I have the same mounting kit and it was great. Unfortunately, with the dragon, I had to shave the mounts to get them to fit properly. Not a big deal... but it was just annoying.
I forgot about that, His is a 2005, mine is a 2006 but that shouldn't make a difference but I guess I am wrongSo, yours went smoothly with this kit, but you had to shave some down on someone else's? That would be disappointing.
It wouldn't be a different clam. They should be identical. Would most likely be the brackets :/ Hopefully they made mine correctly.I forgot about that, His is a 2005, mine is a 2006 but that shouldn't make a difference but I guess I am wrong
This would be the other route:HI, I like the look of the side scoops but have a question as to how they are attached and how easy it is to remove? I have the Radium Engineering clam kit installed on my 08 Elise with the stock side scoops. When I remove the clam the entire side scoop stays with the body and I had to cut through the molding. When I look at the brackets, it looks like brackets 1 and 2 are attached to the clam and 3 and 4 are attached to the body. If I just pulled the side scoop off using the 3 hex screws how hard is it to get bracket 2 and 4 apart so I can pull the clam off. Looks like a small screw holding it together but might be hard to get a screwdriver at that angle without going through the wheel well? Or maybe leave the bracket together and just loosen bracket 2 at the body. Either way, any enlightenment how this all goes together would be appreciated...thanks! (I probably only take the clam off every other year so I guess an extra 10 minutes with brackets won't kill me!)opcorn:
Mark
