1 - 6 of 6 Posts
2001 silver lotus esprit
awesome thanks im cleaning out my rh fuel tank there was a bit of rust in the fuel fuel filter from not driving it and low on fuel so im going to change the hoses in the tank aswell and maybe pumps aswell while im in there. Clean it up im getting hesitation and no throttle and my fuel pressure is dropping when key on engine off once pumps go on so i got a leak im thinkin the hoses in the tank. Ill plug up the bottom elbow with a expansion plug and fill with vinegar and clr let it sit overnight then drain and brake clean it out and air dry it with compressed air then should be all clean. The driver side tank will clean itself im hoping after fuel conditioner and lots of driving.
Keep in mind that the size of the pipe changed several times, getting larger as the cars get newer. I don't know if there was a difference in the S4S vs V8. Sorry I can't actually answer the question because my car is not up in the air, but it might be worth putting your own caliper on it before buying parts.
1 - 6 of 6 Posts
