1 - 3 of 3 Posts
deleted thread? I asked a question a few weeks ago and now the question appears to be gone unless i'm having a rough day... so are all the fuses under the dash on the passenger side? ie. there are a total of 6 or so fuses for the whole car? (one of which is on a separate connector) I searched a while without any luck. And some cars have 2 fuses and some only have one?
Long story short i have a single headlight out and want to make sure i can check the fuse if new bulbs don't fix the problem, but if my 2006 definitely has only one fuse then i don't have to worry about it being a fuse issue...
it seems like a sticky showing the fuse locations and fuse functions might be nice in this section... maybe that got me deleted? ;) it may be in the manual? but it would be convenient info when you're doing research and are NOT near your car. :nanner:
The main 22 fuse block is located under the front right hood access panel. There are 4 fuses for the headlights;
F17 - LH low
F18 - RH low
F20 - LH high
F21 - RH high
By the way there are 8 additional fuses for other circuits in the engine bay.
All this info is in your handbook.
Cheers Michael
perfect, thanks!
1 - 3 of 3 Posts
