1 - 12 of 12 Posts
I have a large number of items that have accumulated in my garage over the years. Most parts are off Lotus Elise's with some out of Celica 2ZZ
Please make reasonable offers, I don't have the time to look up every part
Most notable parts,most parts are not on the list!
  • hard top headpiece and side pieces - SOLD
  • belly pan for front of the car
  • t3 hub stands- SOLD
  • Front oil cooler (had swapped for a side one from BOE)
  • Oil cooler line that went across the front between coolers
  • 2ZZ Valve Cover (in box) - SOLD
  • OEM airbox and intake manifolds - SOLD
  • Battery cover WITH instruction manual - SOLD
  • 2 stock flywheels- 1 looks new
  • 2 used ACT clutches- 1 has little use
  • Coilover suspension components were taken off at 8k miles from an '11 Original Post where I bought them
  • BOE rear clam support brace
  • Lotus wiring harness- it needs a need ECU connector and probably 1 other sensor connector
Full set of pictures
Interested in injector cover. Pm inbound!
Not sure which year the harness is, i'll post a close up of the ecu connector if someone can Identify. I have own 2x '06 and 1x '05 so it could be either (can't remember)
1 - 12 of 12 Posts
