1 - 20 of 81 Posts
I could not update the list on the previous listing.
I stripped down a track car. It is a 2005 Elise Red car, Paint code B94. I also have parts that were just sitting on my shelf.
Some pictures are here https://1drv.ms/f/s!ApuaYmE1TxEIglhRQTQT0beoH1aY
Parts available:
Interior Parts
Steering Wheel
Aluminum dash support and curved tray
Shifter plastic cover,
Passenger air bag and cover
SRS module
Door sills
Carpet - behind seat, along side of frame, aluminum channels for carpet.
Top Dash panel
Brake parts
Brake lines from MC to ABS, ABS to union in front area.
Brake Booster
OEM Master cylinder
Driver Rear brake caliper
Parking brake handle and connecting cables
Aluminum handle on parking brake - sold
Body Panels
Engine Access panel
Cowl above rear clam
Fender behind front driver wheel
Passenger door
- fiber glass shell
- electric lock actuator
- window motor and glass guides
- latch parts
- grey painted plastic piece behind interior handle
Driver Door
- door fiberglass shell - sold
- Door beam and hinge
- electric window motor
- window motor
- latch parts
- Driver door mirror
rear window
OEM Rear diffuser
Drivers side fender behind the front wheel
HVAC system
heater/AC core
blower motor
outdoor air module
AC compressor
air distribution system
Aluminum Refrigerant pipes
Exhaust
Muffler Stage 2
Muffler OEM
Heat shield
Electrical
Windshield wiper motor
Cobra alarm system pieces
Head lights - no covers
Front Side turn signals on the panel between door and wheel
windshield washer/wiper column mounted operator stalk
turn signal and bright light column mounted operator stalk
Battery cover
Cooling
All oem rubber coolant hoses, radiator and engine bay, heater hoses, etc.
Coolant Tank
3 OEM oil coolers - working no leaks, 1 ea Driver and 1 ea Passenger, 1 ea Passenger needs new bungs attached
Suspension
OEM Rear toe links 2 sets
OEM Front sway bar
OEM front steering arms L & R
OEM damper and springs (rear b121 d 0003 x "character not readable"
Parts are located in Hobart, IN 46342. I do travel to Oakbrook Terrace, IL. I will ship the parts.
Make me a reasonable offer for the parts. I will likely accept it. If shipping is needed include your zip code or you can send me a shipping label.
Send me an email at [email protected]. You can use the PM also.
I don't have or am not selling
LSS Wheels
wheel arch turn signals or lights
wishbones or control arms
front turn signals
visors
Interior trim pieces except what is noted or pictured.
Wheel liners
I need the drivers side door latch i think but I am leaving the country for 10 days and havent got it apart to see what the problem is. Posting here so I remember to check when I am back.
let me know when you need the part.
2005 Lotus Elise; 2007 Lotus Exige S; 2012 Porsche 991S
Do you have an oem catalytic converter?
Do you have the cluster cowl cover - The black plastic that encloses the gauges? I am only looking for the top part that snaps in over the gauges.
Email sent.
Gabe
Interested in the Drivers door mirror if it is the entire housing that attaches to the door. Can you PM the asking price to me? Thanks.
PM'd you awhile back on the CAT are you interested in selling it?
1 - 20 of 81 Posts
