1 - 20 of 24 Posts
Garage Clean Up Sale *New Items Added*
OEM 07 Exige rear panel, removed at 9k. If you have had some rear end damage and doing a repair you may need this. Minor cosmetic wear. This thing is a bit heavy and may cost a bit. I have not found a box for it yet either. Asking $400
I also have trunk carpeting and the foam padding for sale but not listed, shoot me a PM if interested.
Old Items for Sale
OEM Exige supercharged Denso fuel injectors, P/N 2350-YW201, removed at 9000 miles. Asking $200 for a set of 4 – (retail $279 each)
OEM Shifter and Crossgate cables, removed at 9000 miles. Asking $300 for both – (retail shifter $367 cross $388)
OEM shifter linkage assy., removed at 9000 miles, I installed a LETSLA mod, assy. only as seen, no hardware, you may need this if reverting from a LETSLA and going stock. Asking $50.00 – (retail on assy. part by part is over $300)
Eibach coil over springs, sizes 188/350 used, 188/450 used. Will fit on Bilstien track pack shocks. Asking $45.00 a pair – (retail $65 pair)
OEM rear engine mount/insulator, and front engine mount/insulator, removed at 9000 miles. Asking $75.00 for both – (retail $249R & $224F)
OEM 07 Exige S charge cooler, a few digs on the rear visible portion of the cooling fins, removed at 9000 miles. Asking $300 – (retail $1524)
Stainless steel charge cooler 2.5 inch ducting clamps, set of 8, aircraft grade, new in original packaging. Asking $50.00 – (retail $99)
OEM 07 Exige S fuel rail, removed at 9000 miles. Asking $50.00 – (retail $157)
OEM front brake caliper pistons, removed at 9000 miles. If you have had a previously frozen or marred/leaking piston this will fix it. Asking $45.00
I also have an OEM Exige S exhaust manifold with heat shielding and two OEM oil pans, make me an offer if you need one.
Please PM me if you are interested. Paypal only! If you are the first to reply it is yours.
I have about 80% of these items boxed up and ready to ship, I will PM you back with a PP address and a shipping estimate. If there is an overage on shipping I will gladly refund the difference.
Discussion Starter · #9 ·
Please and when I say please, do not PM me and say you want an item asking for payment info, then not pay me. I think 24 hours is reasonable but when I have to turn people away because I'm waiting on your payment and 2 days later I still have not received it, that makes you a douche canoe!
I'll take the AEM FPR and cup K&N filter
Discussion Starter · #11 ·
Bump......New Items added.
I'll take the CF wing endplates
Discussion Starter · #17 ·
Bump.....pipe still for sale!
Discussion Starter · #19 ·
Discussion Starter · #20 ·
Gunny, is that Larini exhaust a drop in replacement for a Stage 3 (through diffuser) exhaust? It looks a bit smaller than what I have.
Yes.....Worked fine on my Exige sorry I don't have any pictures.
1 - 20 of 24 Posts
