61 - 80 of 100 Posts
1. Camera input
This facility takes a UVC input (USB Video class) which is a standard used for plug and play (no driver needed) USB cameras
In order to use it as a reversing camera a composite video to USB capture device can be used along with a standard reversing camera (like the ones that replace number plate lights)
The video displayed on screen is not reversed and is not required when a reversing camera is used , the demo seen in the video shows the road on the right hand side which is where it is.
This is one of the "beta" features enabled in the dash for users to try and give feedback on how it should evolve,
so far
1. add a function to enable/disable the camera loading on startup (this will add a 5 second delay to the boot time of the dash instead of when the camera screen is triggered)
the delay is only once per boot and not every time the video screen is shown.
2. Map the camera screen to an input , so the reverse switch/lamp can be used to trigger the camera screen
the USB capture devices tested
https://www.febon.net/ better quality not massively , much higher price ,
much cheaper and works fine ,
Wholesale UVC Driver Free One Channel Video Capture Card AV to USB | Aulola UK
https://www.aliexpress.com/item/2015-new-UVC-Video-Capture-device-capture-analog-video-from-VHS-Hi8-Camcorder-to-PC-no/32529906287.html
and tested with this camera
https://www.ebay.com/itm/Car-Rear-View-Camera-for-BMW-5-Series-M5-E39-E60-E61-Reversing-Backup-Camera/172559390133?hash=item282d5755b5
Out of curiosity what part reverses the image? The composite device or the camera. Because I have a normal usb camera like this https://www.ebay.com/itm/15M-USB-endoscope-Camera-Waterproof-inspection-Snake-tube-4LED-for-car-detection/112456742903?var=&hash=item1a2ef1b7f7
and its reversed.
Is there a way to get the beta firmware or turn on the beta feature?
Suggestion: If possible, a reverse image feature would save folks a lot of money and/or free up some options.
Also I assume this means you get a dash cam or a reverse cam and not both? Because you would need to somehow select the cam you want for the function you want.
On the Garw website "products" page, they now have an option to pre-order for Dec 18 delivery, so they are apparently making another batch of dashes.
Twice since I had it, I think I had it for almost a year now.
For those of you that have had the screen lock up while driving, how often does it happen? GARW suggested that the unit would have to be returned to solve that issue as it is not a firmware issue.
I've never had it freeze on me during driving... its only done it 2-3 times during startup & I was able to cycle it out by unplugging the harness or recycling the ignition/switch... I've had mine installed since May & have about 3k worth of miles on the dash.
I've only recently started waiting for after the splash screen loads & the dash comes up before I start the car & haven't had it freeze yet.
I also have been told via GARW support to return the dash for a repair once I store the car for the winter.
Toys Performance
Mine locked up the first 3 times I drove the car within about 10 minutes. Since then, I have driven the car about 12 times with no issues. GARW told me to send it back when I put the car away for the winter as well but it's a pain to remove so I wanted to know the frequency at which other people had this issue.
Has anyone NEVER had the dash lock up?
Addict
I have had the dash lock up from a jump start, from a push start and once with the new software version after not waiting for the charge screen to load. I have not had the dash lockup once both it and the car were running. I had one of the first few versions in the US and have only had this issue 3 times, GARW did tell me he was working on a reset feature or similar as the dash does not have one built in once it shuts down independent of the car. I'm not sure if my hardware is exactly the same as the production units that came here so mine could be slightly different.
I got the dash hooked up and everything is working except the oil pressure anyone have any ideas?
Going to state the obvious, you have added an aftermarket sensor. Wired to either Analog 7 or 8. Assigned that analog input to the oil pressure channel. Also, you setup the scale for oil pressure sender.
Later,
Eldon
I have to ask, which screen are you looking at that the oil pressure is not working?
I ask this because I have the GARW dash and have aftermarket oil pressure and temp sending units installed and wired up.
I had a problem with the Race screens, they would lock up and freeze and needles would disappear. I conversed with Alec and he eventually worked it out for me.
However, I am still waiting for the fix for the INSTII screen (the Dragon one) because the oil temp/pressure gauges are not working right.
Look forward to your response.
Lee
Does anyone having problem that when long pressed the Left/Right arrow in the Garw app to enter setting pages, it go directly to page 9 with the red down arrow lit up and prevent using up arrow to navigate to other pages in settings? I can press left/right arrow to select the items on the screen but could not go to other setting pages when using up/down arrow. Looks like down key is stuck. Screen shot attached.
Adapter Version 2 Ic7
Hello, I have bought a display used, but the adapter is not compatible. For weeks I write the company under [email protected], but he does not answer.
I need an adapter version 2 Ic7 for a Lotus Elise MK2. Can someone help me here? Excuse my bad english but i am from germany. Best regards Holger
Heads up.. Garw Black Screen... My Garw instrument cluster has just gone black and I'm unable to get any response fromGarw, [email protected]. Just be aware before sinking in $$.
I've switched back to the original dash and I'm not sure if it would be worth switching back even if they get back in touch.
