Check the gasket between the exhaust manifold and exhaust pipe. The aerodynamics of the car will suck exhaust leaks in the engine compartment into the interior and it will seem like they are coming from the front of the car...Dave
That's a rough one... Thanks for sharing.Exhaust leaks in the Elise smell like gas, not exhaust. I have had this very same thing happen and ,yes, it also made me nauseous. Certainly could be a fuel leak as these fumes or any others in the engine bay get sucked right into the cabin. Unless it's a high volume leak, I doubt if enough would vaporize to make you sick. That said, I was driving down the Ohio Turnpike in the late '70's in a 3 year old BMW 2002 and my wife started whining that she could smell gas. I ignored her until I couldn't take the nagging anymore then pulled over and lifted the hood. There was a steady high pressure stream of gas spraying right on the exhaust manifold. The wife still reminds me of that one...dave
Not really. Just a little leak won't use much if any fuel.That's a rough one... Thanks for sharing.
I can believe the exhaust leak but not the fuel leak at this point simply because of my mileage. I drove 262.4 miles before refueling and put 8.31 gallons in. Wouldn't it show up in economy if this was the issue?
I have opened the hood while the car is running and can't confirm any sounds, smells, or visual displays of gas leaking. I would think that after letting it idle for 10-15 minutes it would have left a puddle in the garage. Then again, it may be a small leak that only happens when the pedal is somewhat depressed.
I hope it is a simple fix. I will enjoy it that much more if they could help me with this one item.![]()
It's oily, but VERY much like gas. My eyes are still watering and burning from my ride this morning. rotflthe various evaps seem to recirculate into the car with the windows down, so if its an oily smell thats probably what it is.
Its a bit concerning you continue to drive the car in this condition...It's oily, but VERY much like gas. My eyes are still watering and burning from my ride this morning. rotfl
My clothes stink too. I left the windows down so I didn't feel too woosy or tired this time.
What a smelly situation. My car has bad gas. I thought my wife's gas was bad enough - now my car has it too. And what's worse? It lingers longer than my wife's bad gas!![]()
