I've dealt with my gauge cluster going in and out after hitting bumps for over 2 years, tail end of last year being the worst, I'd say it worked 20% of the time. Doing some searching on the board I've found many people reflowing the solder joints for the pins on the cluster board which I intend to do while making repairs, however I don't feel my trouble is truly in the board/pins.
I've been able to maneuver the smaller connector (can data feed) back and forth to allow the cluster to come back on and off.. therefore I feel I have an issue with loose terminals in the plug connector. Does anyone happen to have a terminal part numbers or part number for the micro pack that would source these pins out? Lotus of course wants to sell a whole dash wiring harness in order to fix the issue.. I'm not exactly hip to that.
While on this topic, ever since i purchased the vehicle the lighting for the HVAC and Cluster have been inop, I'm not sure if I will be covering two birds with one stone or having to dig in deeper. Anyone had common issues with that?
