1 - 20 of 41 Posts
Hey guys,
I tried searching and couldnt find anything. Are there any addtional gauges I should be running with a super charger? I know the boost is constant depending on the pulley size (if there is not belt slipping). So I dont think a boost guage is need but what about oil temp/preasure or a/f guage?
Thanks.
Boost pressure gauge would be nice if you wanna make sure your belt isn't slipping, Oil temp and pressure should be standard in all cars imo, and A/F gauge when you're adding boost is a good idea.
Hmm well If i went the the gauge pod that goes infront of the shifter console by (i think forced fed) that would supply me with two, dont know where I would put any others haha.
Boost gauge is handy to diagnose boost leak problems as well...
2008 Exige S240
Do any manufacturers make gauges that display multiple parameters in a single gauge? (like oil temp/oil pressure/boost in one)
-Just got the VF2 installed...awesome!
Three gauge panel
I posted a thread about a month ago about a carbon fiber 3 gauge panel that I have fabricated and was looking for about 6-8 positve responses for a group buy. My avatar is a photo of the panel installed in my 2005 SA Yellow. I have a boost, oil temp., and oil pressure gauges in it. I have had only one reply to date.
Pretty sure like 10 people posted in your thread asking for pictures.
Can you please post pics.
as long as you are looking for gauges I'm selling an autometer pro comp silver face voltage gauge over in the FS section.
I never understood why anyone would accept looking down to see the gauges and thought the offerings available were a poor compromise because of space limitations in our car, My solution was a Twenty dollar triple pod from ebay and a can of flat black to mount my DEFI boost and oil pressure and an AEM a/f in the middle - simple, cheap and viewable.
I'm looking for a guage cluster to replace my OEM radio. I can count the number of times I have listened to the radio on one hand. I'll likely also put one in front of the shifter. I'd like boost, oil pressure/temp. The NGK wideband comes with a A/F. Water temp is in the OEM dash. I think that would do it.
i installed mine in the two air vents in the center looks very cool and factory and a custom built lower pod with two boost and wideband afr in top oil pressure and fuel pressure on the lower pod
I'm getting PLX gauges for my Subie, possibly the Elise if I don't get a dash later
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/WKevPRuBZcM&hl=en&fs=1&rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/WKevPRuBZcM&hl=en&fs=1&rel=0" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/Sk9wUUeQ6Qo&hl=en&fs=1&rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Sk9wUUeQ6Qo&hl=en&fs=1&rel=0" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
I use one of these and works good for me
Wide Band Air Fuel Ratio Meter
I have the zeitronix but don't have the boost hooked up. Where is a good place to install the sensor for boost?
Also, where do you have your data logger/box thing mounted, mines in the small holder above the cig liter, I'm not sure if I like it there
Discussion Starter · #19 ·
I agree with you about having them at eye level but I just cant see myself drilling trough the dash for that.
I think I will be going with oil pres, oil temp, and wideband afr.
Now I need to figure out what brand of gauges to use.
00 MRS - 2ZZ NA
I'm s0o0o0o going on the Greddy Infometer Touch route...
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/dT3aRjrN45E&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/dT3aRjrN45E&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
But then again I'll be running the emanage ultimate and the v-manage...so it will all sync up together very nicely! haha
This thing is just too cool though...resets codes...can act as any gauge you want...and can datalog fuel trims so I can keep my piggyback tune happy!
This may be better for you reflash people than the standalone ECU crowd...
1 - 20 of 41 Posts
