1 - 13 of 13 Posts
I'm having some steering issues on my Non-Lotus car and was hoping to find some answers here as the members on this forum are much more helpful and knowledgeable than the Subaru forum members.
My car is pulling left to the left while under 30%+ acceleration. I'm literally holding my steering wheel 5-10 degrees to the right to keep it straight. Once I let off the throttle, am cruising, or on the brakes the steering wheel is back and centered.
Car just had an alignment at the dealer as well as new Michelin Pilot Sport 4S tires. Didn't catch this until I got home, but the front toe spec is -.10 and .11. Is this enough to throw off my alignment?
Front Left Front Right
All measurements in degrees
- 0.8 camber - 0.6 camber
0.11 toe - 0.10 toe (yes negative)
6.4 caster 6.2 caster
Rear left Rear Right
0.04 toe 0.01 toe
-2.0 camber -2.1 Camber
He's on fire!
did they give you the "before" measurements? Did you verify tire pressures are as expected? What happens if you swap the front tires across the axle (does it still pull to the left)? Is it safe to assume that if you are coasting it tracks straight?
Front right tire had 43 psi, where as all the other corners had 32.5. D'oh...
I just put on new tires and had an alignment done too...
Will road test tonight when I go out to dinner. Thanks!
Issue is gone after lowering the tire pressure. Thanks!
Do you think the front toe spec would cause an issue? (-0.10 and .11)
I had asked for 0 toe, but the service advisor kept arguing that it’s only 2/10th’s off and it wouldn’t cause an issue.
* Acme Super Moderator * ** The Enforcer **
Why are you having the dealer align your car? Surely there are better options.
San
Discussion Starter #12
Ended taking my car to an independent shop, had them re-do my alignment and all issues are now gone...
1 - 13 of 13 Posts
