1 - 8 of 8 Posts
After a lengthy search I could not find the Textar Pad for the Lotus. Lotus wants about 1 gazzilon dollars for their pads so my search for front pads continued.
To complicate the matter I pulled the left front pads so now the car is on jack stands. One Autoparts store had a pad for the Lotus--Repco 17-20217D.
So I set off this morning trying to find pads or it was back to the first place. All the local chains did not know what a Lotus was. Is that built by Audi?? My local Car Quest was helpful but, what he could get did not sound any better than the first place.
For fun I stopped by my local Alfa mechanic and he came up with an exact match from a Alfa Milan. I tried them but, they were way too thick. He could order Porterfields for a Lotus but, I wanted the car back together today.
To make a long story longer, I bought the Repco pads (organic I think). So back to the house and sure enough they were too thick. After about 5 to 10 minutes of sanding per pad on a Delta Bench top sander, they fit.
All went back together and I am slowly breaking them in.
Only one pad was worn out--the left front outside pad and I would say there was only about 1mm before I was touching the rotor with metal.
I will try these pads but, I will continue my search for an affordable replacement for the stock Lotus pad that I do not need to grind down to size.
LPM
Uh...brakes are one of the most important safety devices on your car. Why would you skimp?
ed
I seem to recall someone needed front pads at a recent track event, and I think he called Sector or one of the other sponsors, who told him the rear pads on a Nissan 350Z would work. To be safe, you may want to do a quick search here.
Cheers,
-Darryl
LPM
What does affordable mean? Is it solely priced based or does is have a price/performance function?
Lotus wants over $300 per pair, where as aftermarket is $85-125. I gave up my search and bought the Lotus. I don't care how wealthy one is, there is a point where some things seem like gouging, and if there is an equivalent that is just as good, why not buy them?
So back to the house and sure enough they were too thick. After about 5 to 10 minutes of sanding per pad on a Delta Bench top sander, they fit. LPM
:eek:
:huh:
Cheers,
-Darryl
Rear pads from a 350z with brembo package will fit the fronts on the elise.
Rear pads from a 90's viper fit on the rears.
1 - 8 of 8 Posts
