getting the car ready for x-country. Gonna change the old stock wiper w/ a 24" Bosch. Read in the owners maual to depress the retaining clip to remove the old blade. Assuming this is like pinching it up towards the blade body? Rather than pulling it down? Does it matter if I break that little piece of $%^& Offf? I can't get this thing out to save my life. Considering removing the arm from the car to do it. Guess it's a tight fit....
i was near the point of bending the damn arm - it might be "stuck" or something - i'm going to pull the arm off the car tonight, then I can work on it.
I know this isn't much help, as I have a bosch on there now and I don't remember how I took the factory one off..but I do remember it took like 30 seconds and not that much force..
so with that in mind, be careful not to break anything?
Assuming you have bosch..
Squeeze the ridged tabs and tilt up the plastic cap which goes over the wiper arm. Push the wiper towards the the wiper motor, Lift the metal loop on the wiper arm which captures the wiper blade, pull wiper blade away from the wiper motor, slides right off.
Be careful to not let the metal end of the wiper arm smack your windshield when the blade is removed; chips or cracks in the windshield can result. Operation takes less than 30 seconds (I just stepped outside to test it). Installation is reverse of removal.
If you need pictures of the operation, let me know.
just got it. Removal was the problem, the blade was on really really tight - almost like the wiper arm was too thick. Finally got it off, applied a thin coat of wd-40 on the "U", and fought to get the new one all the way on. Seems like a great blade - test it tomorrow durig the car wash. You can let everyone know clam removal was not nessescary .
HK - BOSCH Icon 24A. The 24" blade looks much better on the car IMO. Still looks big. It was like $22 at Amazon.
There's an easy fix for next time. Try lowering the brake fluid level to about half way, that in turn releases the back pressure created by the wiper blade...
Anybody thought of doing this after wintertime drives, on salty roads?
"How to build your own undercarriage washer"
https://www.drbeasleys.com/blog/2012/03/23/how-to-build-your-own-undercarriage-washer/?fbclid=IwAR0YBi2TITmGh81F1BXi9rw2_fkwG7n7EdkbIw9Lr35viuSNfQxI3r6EAkI
Hi All ,
I'm not sure but I think my mfru is partly fried . I was also doing some research and haven't found the same unit as was in my Elise .
I have an 05 Elise I'm the second owner and don't know if it was changed once before , it has about 55k miles .
Here are some pics of the unit ...
It's been a while since I've worked on these calipers. I am not sure if I got the pin fully seated. Does the thin leading end need to go into the small hole on the far/inner side of the caliper? I am not confident I've got it seated properly. I've tapped with a punch but don't want to go...
Hi, i have a 2007 Lotus Exige S (it is a federal version, imported to Norway where i live)
A few weeks ago, on the german autobahn, on my way home from Nûrburgring, it started to misbehave betveen 2000-4500rpm, it is just like it holds back on power, and if i try to hold the trottle pedal...
