1 - 4 of 4 Posts
I have a 2007 exige s
sometimes i somehow put the car into reverse without using the latch? or whatever its called
for example: im trying to put the car into 1st gear but it might end up in reverse... :eek:
im guessing this isnt normal, but i havent been able to find anything regarding this issue
you shouldn't need to use the lift latch to reverse... the latch is to make sure it goes into first & not reverse... or at least that's how my 05 is
Try this:
1. Remove the centre console
2. Check and adjust the reverse selector cable and reverse gate stop arm
3. Adjust the crossgate cable and shift cable if needed
Good luck!
1 - 4 of 4 Posts
