1 - 17 of 17 Posts
Well im going on vacation for two weeks and was planning to fully charge the battery with a tender before i left. Just wondering if the battery will still be good to start the car when i come back and not die on me, thanks!
So is two weeks pushing it? I usually start my car and drive her on the weeknds:UK:
Te best option would be to leave it with a trusted forum member like me!:D It does depend a lot on your battery though. I just had two major surgeries. First one I left it for three weeks and it started right up. Second time it sat for a month and I had to charge it to get her going. And I do have the Cobra alarm active. I think the second time it was just a matter of surgeries being back to back. If I had driven her more than twice in between it should have been ok. But I do hear of others having issues in shorter time frames.
darn someone else beat me to it... I was going to take it! This makes me think of getting a battery tender, comparator, voltage divider and relay.... anyone see where i am going with this? EE anyone?
so do you think its the alarm is the culprit for the second time, but a month is pretty long time. Whenever i go long than 3 weeks i put on her on the battery tender.
You should get the battery tender Jr float charger. Love mines!
Just disconnect the battery. I leave the 10mm wrench in there with the tool kit supplied by lotus. Takes a minute at best. Mind you, I don't leave the battery cover on and I use and Odyssey PC625.
I believe most of the dead or weak battery issues in our Lotuses are caused by the alarm.
Battery Tender jr at Ace Hardware
Agree with OTOmatic. Why not just disconnect the battery? Better safe than sorry.
Just remember to turn the alarm OFF before disconnecting the battery or your neighbors may end up hating you.
** NO ** It may not be ok. Mine was not - in only 2 weeks it was dead. I now keep it on a battery minder - and love it. Perfect.
Pick up one of these: BatteryMINDer Plus 12 Volt 1.3 Amp Battery Charger: BatteryMart.com
And a 12 Volt Cigarette Plug Adapter: 12 Volt Cigarette Plug Adapter: BatteryMart.com
The ones they sell at walmart are junk. The battery tender jr. I've heard mixed reviews on - some people swear by them, others have problems (a forum search will give you more). I also picked up a long extension cord for mine, and just leave it on all the time. :)
Good luck!
Have killed 2 batteries on my 2008 from not driving for just a few weeks. If you have electric power then get a tender. If not, either disconnect or get a simple battery cutoff switch. Sector 111 sells one that works great. I got a small gel racing battery and the cutoff switch and I just turn the dial when I get out and turn in back on when I want to drive it. Mine sometimes sits for a few weeks in an underground parking structure without electrical access and this solution has worked great.
I'm wondering if you misunderstand how a battery tender works. Your idea sounds reasonable for a battery charger but a battery tender uses either a microprocessor or a Unitrode UC3906 to intelligently charge the battery based on the state of charge, based on both voltage and current.
In any case, if I were leaving the Lotus somewhere where I could not keep it on a battery tender for 2 weeks (say an airport), I would install a battery kill switch and keep a dry cell jumper in the trunk.
Gamera The Atomic Turtle
tenderize it.
Will definitely NOT work when you get back.
Disconnect the battery and leave it on the ground next to the car.
Ahh, didn't realize there was a difference between a charger and a tender... thanks for clearing that up
1 - 17 of 17 Posts
