1 - 11 of 11 Posts
When cornering hard, my brake warning light comes on in my dash. Goes right away; seems to directly correspond to lateral acceleration.
I've checked carefully to make sure my leg is not pushing on the e-brake lever. But nope, it's doing it all on its own.
Any ideas?
two:
1. Have you tried searching??
2. Fill the m/c reservoir.
Site's been around since 2004 or so. Much has been covered.
we highly recommend reading the manual, which may have something such as this in it:
With the parking brake released, if the tell tale should light
at any time after the six second check period, stop the car immediately,
as the circuit has detected a dangerously low level
of brake fluid in the master cylinder reservoir, possibly caused
by a hydraulic leak in one of the separate front or rear brake
circuits. In the event of a leak there is a danger that air may
enter the hydraulic system and cause spongy operation and
extended pedal travel. The divided brake circuit should ensure
that emergency braking remains, but the car should not be driven
until the fault has been identified and rectified.
Happy to be of help.
If your MC turns out to need filling, check your brake pads.
What's probably happened is your pads are so worn that enough fluid has been pushed into the system to lower the MC below the fill line - it's rare (and really bad) for brake fluid to just disappear or leak out on its own.
If that turns out to be the case, replace the pads first and bleed the system or you'll just be wasting good fluid.
Elise newb
Another way to say this is, "if you need to fill your MC, you have a problem with your brake system and you need to find it." Brake fluid doesn't evaporate, it flows somewhere, either to make up for pad wear or into the wild.
Use google.
Brake light flicker lotustalk.com
better maybe:
1 - 11 of 11 Posts
