Moving along with track prep and it is time for me to make a decision on a baffled oil pan. I am torn between the GPan3 and the TOC V1.1 of which both are comparable in price. Given the experience of this group, I did some searching and didn’t find a comparison so I started this thread. I have added the detailed descriptions below. Give me your thoughts!
GPan3:
Total Oil Control(TOC)V 1.1:
Sent from my iPhone using Tapatalk
GPan3:
Code:
The gPAN3 is a must if you track your Lotus. This is a direct replacement for your stock pan and will make oil starvation a thing of the past. A heavily-baffled cavity reduces vertical oil slosh. Additionally, the pan has been tweaked for clearance to ease wishbone removal. Oil sensor port has been relocated to the front of the pan to reduce wiring. Optional Turbo oil return port ($45) can be added. The simple, high-quality and beautifully welded gPAN3 is track-focused and easy to install. Works with the stock windage tray and stock dip stick and comes with detailed installation instructions. Data proven performance on track!
Race Focused Design = Better Performance
Redesigned internal baffles & trap doors keep oil at the pick-up.
Horizontal ledges reduce vertical oil sloshing over baffle cavity
more than gPAN2
Oil isolated in a properly sized 'oil control box' around the pick-up during high-g turns.
Size is key to preventing oil from escaping
Stable normal oil pressure in all situations.
Added oil capacity. Approx 6 liters
No unnecessary features
minimal number of ports to reduce oil leak potential
AiM data logger used to confirm adequate oil pressure on track
see Product Reference for info
Simple, Bolt-In Design = Much Easier Install
Works with stock dip stick.
Locator-studs provided to help line up pan.
Flat flanges.
Perfect, flush fit with engine block.
Flat pan walls means you can easily ratchet bolts onto engine block.
Works with the stock windage tray.
Windage tray prevents oil from sloshing up into the crank.
Works with the stock oil pump & pick-up.
Clearanced to ease wishbone removal
Comes with detailed installation instructions.
Beautiful Welds = Strong & Good Looking
Meticulously TIG welded inside & out.
Completely sealed.
TIG welded drain plug.
O-ring gasket for a better seal.
Machined seat for improved seal
TIG welded 1/8" NPT fitting.
For use with data acquisition sensors & other accessories.
Relocated to frontside for wiring ease
Full warranty on all workmanship claims.
Aluminum Construction = Lightweight & Strong
Built with 5052 Aluminum.
3/8" billet aluminum rail.
Model Compatibility
Any Toyota 2ZZGE engine
May not fit S260 unless factory rear subframe stiffner is removed or modified
Other
gPAN3 Drain Plug O-Ring
dash-10 AN Plug.
ID = .791" (20.09mm)
OD = .945" (24.00mm)
Thickness = .1" (2.57 mm)
Code:
Our TOC (Total Oil Control) Wet sump oil pan is a great addition for the street or track car looking for superior control of the oil in the engine while increasing the volume as well.
This pan is a sure fire solution to mitigating the likelihood of a loss of oil pressure in the motor for the track day enthusiast or racer. The additional oil capacity will help to prolong oil life and stabilize oil temperature.
Additional features include
BOE Kerropak oil pan gasket for easy removal/ maintenance. (Other pans on the market require RTV gasket maker to seal the pan to the block).
Additional Windage tray that works with the OEM tray on the block
"Anti-Climb" walls inside the pan
Baffling
One direction "trap doors" within the collection box in the pan.
All Aluminum Construction with expert TIG welding
Magnetic drain plug with o-ring seal
Oil Temperature port on firewall side of the pan
