2005 Elise with the larger Enduro tank.
car had fuel pump problems as the fuel pressure went down to zero the more the throttle was pressed down.
Inspected the pump first by removing it from the fuel gas tank. Upon removing the fuel pump assembly there was broken down bits of green material that look like if you shredded a green Scotch-Brite pad.
Lifted car on passenger side to slip gas down as I filled from full tube on passenger side. Cleaned all this up but did not install the pump yet. Poured filtered gas I pumped out back from full tube to check if more green shards came out and none did.
Is this something that is common with an Enduro tank or did someone put in fuel cell foam and it completely broke down.
Purchased a vehicle about a year and a half ago from a person who ran it on the track only.
anyone have any idea where these green small mulch like shards came from?
