1 - 3 of 3 Posts
for those who have installed the GRP gated shifter piece, i have this mated to the GRP carbon fiber console and once its in and im testing it, im having issues with the linkage hitting the bottom mounting screw when trying to shift into 2nd gear. The linkage hits to the point that it wont go into gear at all. Has anyone run into any issues like that, and if so what did you do to rectify it? Thanks!
If you have room in the 1st gear direction I would think adjusting the cable to move the lever forward would work
Make sure that bottom screw is as short as possible, I had to cut mine a bit for it to clear. The other option is to tweak the brackets that the center console attaches to to actually raise the whole console just a hair
1 - 3 of 3 Posts
