1 - 7 of 7 Posts
Driving home last night after dark and the back light behind the speedometer and tachometer is no longer working.
The screen with fuel, temp and mileage was still lit. It has been getting dimmer and dimmer over the past few months but is now completly dark when driving at night. Everything else seems to be working fine.
Anybody have any suggestions as to what this could be?
Thanks,
You may not have the same problem as i did but this happened to me. Turns out there is a button on the right side of the steering wheel that changes the lighting and if you press it for long enough it dims it all the way off and same goes for turning it up. Just press and hold, for it to dim up.
It worked. Problem solved. I guess I've been slowly dimming it everytime I fill up and reset the trip odometer.
Thanks!
1 - 7 of 7 Posts
