1 - 15 of 15 Posts
Prof Chili mentioned it yesterday at Toad motors, ...
Anybody interested in heading out to H2R to play?
I'll go. I was planning on going on Saturday, but I can change that around. You Houston boys won't get there before 11 though will you? I was thinking about an 9-11 to avoid the heat.
Still waiting to hear back from Brian if hes going... We are planning on tailoring the cars to the track.
I'm taking my motorcycle safety course on Saturday and Sunday. I might stop by after I'm finished with the class.
Discussion Starter · #8 ·
Yup, it's on. What time we leaving? On road by 6:30?
Works for me. But what about Prof. Chili? He's not much of an earlybird.
If we run the normal 11-4 that we usually do then leaving at 6:30 might be a bit to early.. If we leave around 7:30-8:00 it will get us there by 10:00-10:30...
If you leave at 6:30 you could run 9-1 to avoid the heat. It's going to be a hot one. The only issue of course is that you will need a fuel break during run time.
That is why we normally run the 11-4 time slot.. Sucks leaving for gas....
Probably have to leave at 6am to ge there by nine. Remember we have to unload 3 cars of the trailer before we can start running..
Discussion Starter · #13 ·
6 AM bright an early
I'll be knocking on your door to load up at 6 AM. Should take 10-15 min. to load one car and then we can hit the road.
Discussion Starter · #14 ·
P.S. Looking forward to having the Lotus out on track again. Too much BS not enough track time...
Since there were alot of times flying around here. Just wanted to make a final post on when the Houston crew is leaving. :)
Think we are leaving from Chili's house by 8AM. That should let us run the 11-1 and 2-4 sessions and still get home while it's light out.
Doghouse, check your email or reply back here so you don't wake me up at 5am or anything. :)
1 - 15 of 15 Posts
