1 - 20 of 66 Posts
My clock and location show where I was yesterday at 12:35 p.m. and I can seem to get it to update. I don't have the Alpine manual.
I had mine freeze a few months back. When I went to the dealer for service, they called Alpine tech. They were told to reboot it by disconnecting the battery for 20 minutes. It worked and I have not had an issue since.
You can read the manual here (But I don't know if it mentions how to reboot): http://support.alpine-usa.com/products/documents/OM INA-W900 English.pdf
Thank you. I found a similar thread where the solution was to press the rest button. That seemed to work for me.
I had this happen with my car. I ejected my portable Nav unit from the head unit. I then put it back in, and turned the car off for a short time. Then restarted the car, and all was well.
On a related note, my car is going into the dealer Tuesday for a new Nav unit.
This supposed to be an updated unit. Once installed it is no longer portable. This fine with me, I have never used it outside of the car. I have been waiting since August for this part to come in from Alpine. They seem to be worse to deal with than the government! Hopefully this solve my Nav problems with the Alpine. Turning it's self Off and On, not holding a destination in the memory, and the Alpine not working with my I phone from time to time.
Ron
I took my Evora into Galpin Tuesday morning for the Nav unit replacement. This is the third time they have replaced the portable Nav unit. The replacement did not work properly. The screen would go black after a few minutes. So the dealer called Alpine, and they are sending another unit! I told the dealer that this is a big wast of my time as well has there time. I asked them to get me a price on a Kenwood or Pioneer unit form there stereo shop. The price was $1900 installed! They are going to ask Dave at Lotus again if he can upgrade me to the Pioneer unit from a 2012. This has become ridiculous.
Ron :wallbang:
Nav Unit
I fully understand your frustrations! If you can get the Pioneer unit, you will have a better navigation unit. Just so that you know. I have a Lotus Evora S IPS MY2012 which came with the Pioneer AVIC-F930BT unit. Pioneer recently informed me that they had decided to change the maps to those from Navteq. The Pioneer NAVIGATION UPGRADE microSDHC-CARD 2012 Map Update cost me 149,00 Euros, and was sent via courier service within two days. With this upgrade, not only are the maps upgraded to Navteq 2012 data, the Pioneer system is also upgraded to the equivalent of the Pioneer AVIC-F940BT, so functions and operations become identical to those of that unit. Pioneer therefore advises to download the Operation Manual for Pioneer AVIC-F940BT and use that from the upgrade onwards.
So if you upgrade to a Pioneer unit, you may want to get the Pioneer AVIC-F940BT, with a Navteq 2012 update.
Hope this helps
Bart
Hope this helps
Bart[/QUOTE]
Thanks for the info, I will look into it.
Ron
Ron :wallbang:
Ok, I just got back from Galpin (my Dealer). They installed my 4th replacemente Nav unit.
I no longer have the Portable nav, they sent an upgraded unit, it works alot better. The menu's are diferent as well, and the phone pairs up much better.
So I will keep my fingers crossed.
Update, 1-1-13. I backed the car out of the garage to add a station to my Satelite Radio (just activated,never had the free trial period).
The radio did not go to it's Evora graphic splash screen, instead it displayed the set menu for the Nav (this is the same screen that my dealer used to set up the new Nav,when they installed it just a week before) As fare has I know it is not suppose to come on after the set up. I could not get past this screen, the touch screen buttons for the set up did not work. I was able to go to my Radio screen, and add my Satelite station, but I could not get into my Cell phone screen or the Nave screen. I ejected the Nav unit, still nothing. I turned the car off and on a few times, nothing. After a few attempts I was able to press the Nav setup touch screen button. This got me into the Evora Splash screen, and then the screen where you select the language and the agree to the safty message.
After that every thing worked as it should. I went on a New Years day drive with my daughter (in her Elise) and some other friends. for the day.
I called the dealer and told them that I have had it with this head unit!
Since Alpine or Lotus will not replace the entire head unit, my optins are limited. I asked the dealer to give me an estimate for replaceing the Alpine with the Pioneer that the 2012 Evora's come with. It really bugs me, that I need to replace the stereo in a car that was $85000 + with my own Money!!
Ron:wallbang::wallbang::wallbang:
likes to drive fast
Galpin replaced mine to the non portable unit too some time last year. No problems or hiccups.
Tell me about the sat radio. I never activated. Can i get a free trial? I have the INA-W900BT Alpine.
I don't think you can, If the dealer did not activate it when you bought the car, then no. When I called them that is what they told me. It was $190 for the first time fee, then on my renewal it will be less. It is great to have, my wife has it in her new Mini. If you go to the audio source screen, and select the satellite option. You will get a demo intro. On the screen should be your specific radio / sat #. You use this when you call to set up your new account.
Ron
Software Update
I do know that there is a software update for the Alpine INA-W900 unit. I have not applied the update but it does list the following as items that are updated:
  • Enhanced GPS freeze detection and recovery mechanism
  • Improved Navi OS recover in registry corruption
  • Improved UI for single digit odd number address entry
  • Voice Guidance correction
  • CPU/GPS update for memory map error and titan L2 cache
it can be downloaded directly from Alpine:
Alpine Electronics of America, Inc.
Thanks for info, the last Nav unit that they sent out has all of the latest updates. That is what they told me, but how knows.
Ron:shrug:
You can verify the software version from the unit:
  1. Press the Navi Menu button below the screen
  2. Select the Info Button
  3. Select System
  4. Check the Application Version
The update is version 1.001.000 :nanner:
I was without Sat for a good 5 months due to the radio equipment NOT being warrantied through Lotus but some third party... I get it replaced this weekend and hopefully get my Sat back.
  3. Select System
I just did the update. Very easy.
At the risk of this being a stupid question, how do you perform the update on the unit? or put another way How do I download the update to the unit?
Thanks
www.theapexinn.com
EVERYTHING is frozen in Michigan.
Thanks
Here is how to do the Alpine W900 update. It is very simple
See above for the link to the download and the manual.
1. download and unzip the update (it will have a pdf set of detailed instructions in it)
2. copy all unzipped files and the one folder to an SD card (at the root of the card not in a sub-folder so it can be recognized by the head unit)
3. open Alpine face and open little SD card slot next to CD (with your fingernail)
4. insert SD card, close the plastic slot cover and close front of unit
5. go to nav setup (wrench)(use brake/handbrake move to access setup menus)
6. find the nav update section (use page down button)(if files are not right the update button will not be lit/active)
7. tap the update button
8.ensure car is on (running is best so no timeout, i did it while warming in the dirveway)
9. wait for the confirmation dialog box saying successful update.
10. enjoy........:up:
you do not need to reset/reboot the unit.
use the system section to verify your new version number.
Summary instructions
download
insert card
update
grin
1 - 20 of 66 Posts
