1 - 4 of 4 Posts
When I turn off the headlights, the pods stay up but lights go out and I hear the relay click.
I put one down manually but same symptom when i turn them on and off again.
I removed the headlamp pod delay relay (green). They stay up.
I swapped the pod delay relay with another - they stay up.
I disconnected the battery and re-connected it - no headlamp action - even when I had put both down manually.
Does anyone have a solution to this issue?
Thanks,
Guy
don't say the switch, don't say the switch, don't say the switch
If you swapped it then that leaves 2 possibilities, both modules are bad or you have a wiring problem. Start by checking the connectors in the plugs to the modules. A dim possibility but you can test each motor by applying power directly to each and reversing the polarity to run it the other way.
David Teitelbaum
1 - 4 of 4 Posts
