Add me to the list of people with random headlight problems.
My driver's side headlight and the small lamp bulb are out. The high-beam works just fine. I've checked the fuses and the switch panel with no luck. Any ideas? Obviously there could be a problem at the lamp assembly itself, but I didn't want to have to take it apart again if I can help it.
I thought I'd check here quickly to see if anyone else had a similar issue before I jump in.
(That being said, I had never taken the switch panel off before and it ended up being more work than it would have been to start with the headlight assembly!)
