1 - 7 of 7 Posts
My headlight control module is toast, I've been turning them up and down manually because one side just clicks, goes down but not up. Anyone know does a 98-02 firebird control module (part in the driver fender well) cross reference, it looks the same.
good luck with the replacement
I had an issue with mine not too long ago, when I first called the dealer shop they laughed at first...apparently it's a mystery to what was actually used in each car.
The module comes from either a firebird or sunfire, my local tech tried 2 replacements. They looked identical but neither worked, fortunately he was able to get busy with the soldering iron and fix where the board had cracked.
Best of luck, I hope that someone else has better information for you.
Its definitely the module thats bad, I ordered it for $8, if it doesnt work im only out $8. But I can probably use the transistors out of it to fix mine worst case scenario provided they are similar.
Integrator
Carefully open the back cover and check your power transistors for crispiness or water intrusion. Mine had signs of H2O on the PC board. I have added heat sinks to the power transistors to prevent overheating. They burn out too often to take a chance.
See pics there: Lotus Esprit Turbo (1988) - Garage System - The Lotus Forums
1 - 7 of 7 Posts
