1 - 9 of 9 Posts
Thanks for your reply
Ice removed the screws underneath but it will only move from side to side and not pull out
Pull harder ;)
The surround is attached to two little rails that are pressed it. Pull straight out (horizontal to the ground, towards the engine) and it'll come out
Arg still wont budge. There are 2 clips at the top. Should i try shoving a knife in or should it just jeep pulling?
Hi guys :) got this sorted and thought I would let you know how to do it as there is nothing about it anywhere. Instead of just pulling it towards you, you need to pull it downwards and it will pop out then it simply pulls away.
It's only simple when you know how haha
Thanks for all your help
Jonny
1 - 9 of 9 Posts
