Interestingly enough, the wiring diagram definitely shows the headlight and parking light switches as maintained (on/off). However, what is not shown, is the logic circuitry in the switch pack module, that could very well mean that these switches are momentary.
Well, if you think of how the headlight switches work, it becomes apparent that they are momentary and the logic is in the switch pack module.
If you push the parking light button, the parking light turn on. Pushing it again turns them off.
Now, push the head light button. The head lights and the parking lights turn on. Push it again, and only the head lights turn off. You have to turn off the parking lights by pushing the button (that you didn't push to turn them on). The parking light switch is not "latching" in an on or off position.
The only way the above works is that they parking lights switch has to be a momentary switch sending a "signal" to the the switch pack module. Since both the parking and head light switches are the same, they are both momentary (Also this has been confirmed by people that have accidentally switch them when installing the driving lights).
If I remember correctly the AC button works similar. If you push the button without the fans on, nothing happens. Turn on the fans, and then the button and the AC turns on. If it was a latching switch (on/off switch) then pushing the button should leave it in the "on" position and the AC would turn back on if you turned on the fans. Additionally, if you have fans on and AC on, the AC on is canceled if you turn off the ignition, then turn it back on. Again, it's a momentary switch.
Now, the function of the driving light switch does "latch". Push the button, and the driving lights come on with the high beams. Turn off the head lights and/or the ignition, and when you turn the high beams on again, the driving lights will be on. That switch "latches" - on or off - and stays that way untill you push the button again.
And again, it's all been tested by people with multi-meters to check continuity...
