A few reports of coolant leak at the valve because the worm drive hose clamp got loose.
I used 7/8 constant tension hose clamps. hose clamps
The plastic universal vacuum tee I got was too small for the brake booster hose.
A metal 2mm-6mm-12mm Tee 3-Way Brass Tee was perfect.
Vacuum Tee
Pig tail for the EGR solenoid valve
I made an extra control box that controls the EGR solenoid by the flap actuator control voltage, I fixed it behind the wiper motor and it got in the motion path of the wiper arm. The wiper motor got very hot because it was stuck at the wrong place.
Verify your wiring and vacuum lines are not interfering with the wiper before you button up everything.
Vacuum Tee
