Thanks to Rob (who pointed out the obvious vacuum source, DOH!:wallbang: ), I re-invented the whole thing and it is working great for me. One hour ride yesterday that was nice and cold. Heat comes on very quickly after switching out of bypass mode. Best thing is there are no real custom parts. I have an extensive write-up with pictures, parts lists, cost and diagrams atttached. I would be willing to put some kits together if people are willing to reimburse my time and shipping. Maybe $25 bucks (?) above parts and shipping for running around and packaging. My feelings won't be hurt if no one is interested. I'd like to use the $$ to start working on a short shifter solution (at the transaxle, not the lever).
Now to the disclaimer. This mod works great for me. I can't promise it will work for everyone, but I don't see how it could hurt. Easily reversible if so desired. Use at your own risk....affect on warranty unknown....your mileage may vary....CMA...CYA.....
BTW - I see no difference in indicated coolant temperature with or without the bypass
I think we should get a handful of testers (2 or 3) to check their results before we go wild with this mod. I sent Rob a preliminary document and I think he's working on an install now. Hoepfully he'll post results.
To the poster with 226 degrees. That sounds like a problem with your specific car. I've never seen 200 degrees and almost never see 193 (maybe 2 or 3 times in almost 2 years). Check you fluid levels, check for vacuum leaks. Use may want to try some Red Line Water Wetter (I'm a believer).
Thanks Bruce, that explains a lot. First, I have never heard it come on, and probably won't. 110 C is the same as 220 F, which is probably possible to reach after turning off a hot engine, although I always run my engine for 30 seconds or so before shutting it off on a hot day while I wait for the temp guage to start declining, indicating no hot spots left in the engine.
What about a solenoid operated water valve in the engine compartment which is held closed with power on it while the engine is on, and when the key is turned off it opens. Then in the winter, just pull the wire off of it. Seems to me an easier way to stop the water circulating and heating up anything. Any thoughts? Thanks. Pete
Nope, the recirculation pump is controlled by the ECU. After you shut down the engine, the ECU monitors the temperatures for about 20 more minutes. If it detect that things are "heat soaking" then it turns on the electric recirculation pump to circulate water through the head to the heater core. This prevents localized hot spots.
What is not known is how much heat removal is done by the heater core, verses the lines up to the front and back again. In any case, that is the reason for the vacuum controlled valve - when the engine is turned off, the valve go out of "bypass mode" and water is again circulated through the heater core.
Making it a manual bypass valve by the engine, would defeat the purpose of the recirculation pump. Even making it automatic (like the vacuum operated on valve) might cause problems with "cold" water from the bypassed heater circuit is suddenly recirculated into the cylinder heat. That's why the bypass valve is mounted up front - all it is removing from the circuit is the actual heater core (removing it as a heat source in the HAVOC box).
It would be possible to put a manual valve in the vacuum line to turn off the bypass in the winter, and make it automatically come on in the summer if you wanted to save the effort of doing the electrical wiring. But I would think that the on-off switch would be worth the effort.
I've never heard mine come on either. But then again, I have yet to wait around for 20 minutes listening for it either. I suspect that it must be a distinct possibility that it can be needed, or Lotus wouldn't have gone to the trouble to have installed it on the car. I believe that someone had simply disconnected their heater by replacing the hoses at the engine with a short one to interconnect the in/out at the engine.
I like the safer way of mounting the bypass up front - keeps the recirculation pump/system for heat soak, and should prevent thermal shock (even if that isn't a serious problem).
But there is not reason that you couldn't use an electrically controlled valve like you figured, and mount it up front. Or use a vacuum controlled valve with a manual on/off valve as I posted above...
110 C is 230 F I think. Toyota doesn't use the heat soak on any of their 2ZZ cars. It's peculiar to Lotus. But I guess some Elise get driven harder than Toyotas.
But I have another question about the Lotus Heat Soak procedure. Why do the fans come on at 115 C? That's not the circuit the water is flowing through. I definitely know my fans have never come on after the car has been off. An interesting experiment would be to bypass the heater core up front by just switching the hoses and see if the cooling fans ever come on. That would indicate that enough cooling isn't getting done just flowing through the pipes and hoses.
I hope it helps your car...I would agree with you that it's messy and that the anti-freeze is slick which can make it b*tchy to get those clamps on. I went throug 3-4 pairs of nitrile gloves during that part just to keep some grip.
So I finally finished installing tonight. Haven't had a chance to drive car. Test of the setup works good so far though. Valve comes right on with the switch, and shuts off quickly when the car is shut off.
I actually use an Audi air solenoid instead of the one Tony was suggesting. Why? Because I had a couple spare ones lying around The are of 99 A4 2.8. You can use these, but you'll also need a Bosch 2 wire plug to plug into it. Regular push on leads won't work.
This mod was more of PITA than I thought. Working in tight crammed spaces sucks like no tomorrow.
For getting power to the switch, their is 12 volts switched power right in the AC control head. The fan switch has 1 lead that is hot with ignition. It is the lead labeled C on the back of the switch. I just used that to grab my power for my solenoid.
Wow, this was wayback in Oct 04:huh: ....I took the grill off the car and opened up the fresh air intake for the climate system. Just used a cut-off wheel and opened up the intake considerably wider and extended it onto the top of the vent rib as well. Then I siliconed new screen over the holes to keep small children out.... I completely forgot I did that until just now. The idea was to cut down on the freezing by getting more air through the system. I recall this did increase the air flow noticeably. Sorry it just occurred to me now...:wallbang:
What I was going for was to cut down freezing (more air flow = less freezing..at least when not in recirc)and also to increase air flow in general for all climate modes. It’s pretty straightforward mod and can’t really hurt anything. If you take the grill off, you can see they’ve just got screen over the climate system intake openings (on the ends of those 3 big ribs) with a bunch of tar-like goop holding it on. I just peeled them off exposing the intakes to the climate system. I used a 3” cut-off tool to slice the sides off the existing opening to make it wider and taller. I also extended the opening on to the top of the rib a bit (inch or so). I think I probably increased the square area of the inlet by 40%-50%. Just seemed to make sense to make it less restrictive on the intake side. That’s why we pay for all those cool air cleaner elements.
Procedure:
1) Remove plastic “bolt” in middle of grill (pic 1)
2) Release 4 brackets at top of grill my gently pushing on the tab at the bottom of bracket while simultaneously pulling the top of the grill towards you (pic 2)
3) Once all four bracket are loose, pull the top of grill toward the front of the car and work the grill pegs out of the holes in the bottom of the grill “mouth”
4) Peel off the existing screens over the fiberglass ribs to expose the climate control inlets. Widen these as you see fit to maximize air flow.
5) Use black silicone and new screen (if your old screen is no longer able to cover the opening) and glue it back in place like it was originally. I came up with new galvanized screen from a gutter cover with almost the identical pattern as the original screen. Most any expanded metal or hardware cloth will do. (pic 4)
6) Replace grill.
7) Feel the bigger breeze…..
NOT MY BEST LOOKING WORK!! What a real hack I can be, but not usually. I meant to come back to this and smooth it up, but it just fell to the wayside…. I think I’ll fan a little flat black while I’m in here….although the Lotus OEM one looks just as bad or worse (far right).
As usual, no guarantees, no warranty, your mileage may vary, your responsibility, I am rubber, you are glue, etc.....:wave:
I am not sure what I am looking at exactly on the intake mod. Do those openings go back imediately into a larger plenum? If not, it looks like the ribs are the "duct" and the cross sectional area of the ducts which did not change is now the pinch point so not sure how you would get more air flow to the fan..
The ribs form three plenums that feed the intake to the climate control system. The openings to those plenums (at least on my very early car) were considerably smaller than the plenums themselves. The holes just weren't cut with much care. One other sort of jungle math bit - I'm pretty sure the vent hose on the output side of the climate control is 4" diameter yielding 12.5 square inches of area. For my car (the only example I have ) the inlets in the ribs probably had more like 8 or 9 square inches (approx. 1.5 *2* 3) of total area. Again the cut-outs did not "port match" to the plenums very well. I widened the openings as much as possible without getting into the corner fillets which still left some restriction at the opening. I extended the opening onto the top to get more square area Imagine a big carb vs. small carb. Bigger venturi gives more CFM or try drinking coffee through a coffee stirrer. I think I'm on solid ground here, but am open to opinions.
I have always thought the air flow was too weak on my car so I took a look through the grille on my '05 (late production) and only two of the intake plenums were opened and covered with the mesh. The middle plenum was uncut and totally sealed while the two open plenums were completely plugged with bugs, leaves and road crud. I cleaned all the crud off the mesh with a stick and a wet rag, but I need to pull the grille and clean everything thoroughly when I have more time. This looks like another cleaning chore that I will need to add to my list on a yearly basis. When I pull the grille should I cut open the center plenum or did the factory leave it uncut for some reason?
Tonywa28 said:
The ribs form three plenums that feed the intake to the climate control system. The openings to those plenums (at least on my very early car) were considerably smaller than the plenums themselves. The holes just weren't cut with much care. One other sort of jungle math bit - I'm pretty sure the vent hose on the output side of the climate control is 4" diameter yielding 12.5 square inches of area. For my car (the only example I have ) the inlets in the ribs probably had more like 8 or 9 square inches (approx. 1.5 *2* 3) of total area. Again the cut-outs did not "port match" to the plenums very well. Imagine a big carb vs. small carb. Bigger venturi gives more CFM or try drinking coffee through a coffee stirrer. I think I'm on solid ground here, but am open to opinions.
I had the same thought when I looked at the structure. I wouldn't open up the plenums on the top, but I can't see why enlarging the existing holes to their edges would be any different than the crude holes Lotus cut into the face of the plenum structure. I am mainly curious as to why the photo on this thread shows three open plenums while my car has only the two outer plenums open and the center plenum uncut.
I don't actually remember if I had two or three cut-outs
I think three, but again, my car was very early (#62) and I made the mod almost two years ago:crazyeyes . I'd like to believe they did a better job on the openings on later cars, but I'll have to hear from others on that subject.
OPINION - As far as crash structure, look at the rib, be your own judge. You can feel the thickness of the top of the rib through the factory opening. You could conceivably say the beam is not as strong due to the removal of fillet corner on the front edge.....My opinion is fiberglass is a LOUSY impact material (well that's just fact). It's brittle and shatters right away without absorbing much enegy. Strong within its limits, but sudden and ugly in failure (my family had a boat company when I was young, I saw lots of fiberglass failure boats vs docks, briges, piers, etc). I believe the desirable quality of any impact absorption device is to deform and absorb energy over distance and sacrifice itself, not shatter and be of little consequence or be so rigid as to deliver an impact shot right to the footwell/frame. Remember, its that sudden stop that sends your brains out though your nostrils:no: ....The change I made is miniscule (this is the opinion part), but again be your own judge. Heck, it might have improved the crash absorbing cabability for all I know by introducing a new shape that deforms better before it shatters .
A bit off topic but sort of relevant...Chapman recognized this way back in the early cars. I can remember updating my Elan with nice shiny big tubular a-arms over the original stamped steel channels because I thought strong and heavy was always good. Then a revered Lotus tuner pointed out that now any curb impact that I had was going to send the shot straight to the stressed skin frame rather than the orignal a-arms sacrificing themselves.....much more expensive proposition to replace a frame than replace a-arms...Chapman was a genius because everything was sized correctly for the job, no more, no less and he tried to get multiple uses out of parts (frame sections carrying vacuum is an example). He seemed to more get more performance (at least the kind of performance I like) from the sum of the parts than other manufacturers.
I'm sure there are some structural, civil or mechanical engineers with the proper education that can weigh in on this subject.
I took my car apart (and cut myself nicely) to try and see if I could determine whether there were two holes originally or three. I couldn't tell, but I'm very much leaning toward the idea there were two original holes and I added the center one. Old age is tough on the ego..... I did verify that the center hole does draw air, so I guess I not only increased the area in the existing hole, I added a third hole which raises the input area by 50% even if you don't go into the top of the rib. Also checked the thickness of the fiberglass of the rib.....it was less than 1/8 inch...... Measured the area of the one original hole and it was right at 3 square inches.
So back to my observation about the stock set-up:
The vent pipe from the climate system to the car is around 4" in diameter yielding 12.5+ square inches of area. The original openings for climate control intake were close to 6 square inches (2 openings * 3 square inches)....
So for those folks who don't want to cut on top, you could still add a third center hole with screen just on the front of the rib.....unless folks think that compromises the "crash" structure.....-poke-
It's all about the opinions!!! and we all are the absolute undeniable authority on our own!
As always, no warranty or liabilty is accepted for changes you make to your own car, I'm just posting what I did as an idea....
Just have fun,
51.4K members
