1 - 9 of 9 Posts
Hello all!
I'm Pranove, I recently pulled the trigger on an 2005 Lotus Elise and I'm so glad that I've made the best decision. Had this Lotus from someone I personally adore and it was him who introduced me to Lotus. I'm based in Portland, Oregon and I'm making the best use of this summer driving through twisty roads around the forest park.
I'm here to learn as much as I can. Been following the forums over 3 months ever since I had the opportunity to drive one for the 1st time. This is my 2nd ride, I come from a 2018 Dodge Challenger RT 6 speed.
I have Go Kart racing experience back in my teens and driving the Lotus brings all those good memories.
Happy to be here!
1264178
2011 Lotus Evora
I’m a new Lotus owner this year (got an Evora in December) in Portland Oregon too. Unfortunately much of the car events are shut down with covid but at least we can still enjoy solitary drives.
You probably already know about the high performance driving classes at Portland International Raceway. I was going to take a class in May but postponed now until September and not sure it will even happen then since the instructor is closeup in the car with you.
The Portland cars and coffee used to meet at the world of speed near Wilsonville but since that museum closed due to covid it isn’t clear where the new meeting space will be when things open up again. Here is their website: Home - Portland Cars & Coffee
I joined the club northwest northwest too so maybe will see you at some in person events in the future.
Greg
Hello @greginportlandor
I'm aware of the classes at PIR, hopefully everything goes to normal soon so we can all meet. I'm eagerly waiting to take the Lotus to track as I've never tracked a car before. Also, there's AFBM-All British field meet in the month of September at Wilsonville not sure if they would reschedule it too.
Good for you.
Lots of fun ahead.
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need...
Plus, “How to bleed brakes”:
How to Bleed Brakes
How to Search:
Discussion Starter · #8 ·
Good for you.
Lots of fun ahead.
5. Transmission:
And, use:
How to Bleed Brakes
How to Search:
Thank you!
1 - 9 of 9 Posts
