1 - 16 of 16 Posts
I was on the old forum but haven't used the site in a very, very long time. Owner of a supercharged 2006 Elise in Aspen White that has been in pieces for 4 years. Finally got off my tail and rebuilt the car. Drove the car for the first time in years this week and fell in love with it all over again.
I also race in a few wheel to wheel series and will take the Elise to the track for time trials and/or track days when I'm not racing.
Administrator
Welcome to LT! I bet that you're glad you got it back together!
6.94915254 lbs/hp
Where in TN are you located? I'm in Nashville FYI.
2020 Lotus Evora GT - Vivid Green
At least 5-6 of us on this board from Nashville area
Hi! Chattanoogan over here.
07 Exige S
How D, I am in Knoxville.
Last time I went up to the Dragon was late one weekend this last summer. never fails.
Maybe we can all do a meet and greet or whatnot this summer, or whenever makes sence.
Sounds like this “excuse me”….
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
These (lube, mods) make a huge change in shifting. I also reoriented one swivel joint.
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need...
18. Many benefits to joining Lotus Ltd (USA Lotus club). Get help wherever you are, using the contact booklet they update every year. (I’ve helped a few ppl who called me.) This is who stages LOGs (Lotus Owner Gatherings) every year. https://lotusltd.com
Plus, “How to bleed brakes”:
How to Search:
Discussion Starter #11
5. Transmission:
And, use:
How to Search:
All valid and experienced more than a few of these issues. Lost the oil cooler pulling onto the interstate (on the way to an auto-x) years ago. Switched to a laminar flow oil cooler afterwards that works great. Number 12 is particularly annoying as well.
Loves to talk
I’m in Nashville We‘ll put a drive together when we get some reliable weather. I’ve got a racing green Evora.
Discussion Starter #15
There’s a couple of us in Memphis. Well I’m in Bartlett but it’s close enough. I have an Aspen White Exige
Nice, I'm right at the edge of Shelby county in the Collierville reserve.
Also, not sure if you know but NASA is running a track weekend in Millington this February 19th to 21st. Let me know if you are interested.
2006 Lotus Exige
That sounds fun. I will let you know when I get my Feb schedule.
1 - 16 of 16 Posts
