1 - 9 of 9 Posts
shay2nak
:wave: congrats! post some pics!
Welcome and congratulations.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k.
5. The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
6. As per some engine builders on these sites, wait AT LEAST 20 minutes after coolant has reached full operating temp before engaging cam switchover.
For street cars, consider removing one or both oil coolers. Some cover them.
http://www.lotustalk.com/forums/f311/cooling-ticking-timebomb-how-your-cooling-u-tube-47232/
http://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
14. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
15. Most parts on the car are made by Toyota and others, so buying things like a/c compressors, engine parts, etc. is wildly expensive when purchased thru Lotus.
16. The soft high-grip tires on most of our cars lose much of that grip when temperatures drop below 50 F. I know of too many ppl who spun their cars when not remembering this. I use hi-performance all-seasons.
Plus, “How to bleed brakes”:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
Discussion Starter · #7 ·
Wow, thanks for all the feedback. Prior to shipping car Hayes from wire wheels sent car to lotus deler in Orlando to take care of recall for oil lines. The headlights have also been replaced. Have to look into some of the other items mentioned. I appreciate all the help and love the car. Totally different from cars in the past had a mustang with a Paxton supercharger another mustang with a vortech charger. Currently have a 1993 firebird with a pro charger but none of them give you the sound that I get from Lotus with VF with intercooler.
Wingless Wonder
1988 Esprit Turbo
Where in NY? Downstate or Buffalo/Rochester? There are active Lotus clubs at both ends!
1 - 9 of 9 Posts
