I asked this question in the "Hi, I am new here" section, but figured this was more suited as a general discussion item, since it's a problem I'm experiencing with the car.
For some reason, I am unable to rev my Elise passed 6300 RPM. Even with the car fully warmed up (temp about 190 F), I get the red RPM tell tale light at 6000 RPM and then I start bouncing off the limiter at 6300 RPM. Only once was I able to rev up to 8000 RPM after I had switched on valet mode and then switched it back off...but then I tried again 3 minutes later and the 6300 RPM limiter was back...
Has anyone experienced this problem before? Is there perhaps a valve that controls this that could be broken? If so, where is it located? An easy fix?
Thanks!
Thanks!
