1 - 4 of 4 Posts
2005 Elise won't start. It cranks but won't fully start. This is the first problem Ive had with it. CEL and oil light come on. There's no oil leaking and the level is fine. I just have no idea whats wrong.
Mulholland>SCC
First car?
The warning lights on the dash are supposed to turn on when you turn the key to on and do not start the car. It is to let you know the lights work.
Check your battery connections. Do you own a voltmeter? Your battery should read 12.8 volts. 12.2 volts is dead. Do you have a battery charger? Put it on your battery. Or if you have jumper cables and another car, jump it.
Your battery is suspect number 1.
Sorry couldn't resist :)
1 - 4 of 4 Posts
