Drove 300 miles to NJMP on Fri. Sat, I ran a session and after appox 15 minutes it began to stumble. I came in with motor shutting down several times. Now the car will run poorly for a while but once it's hot the stumbling and backfiring comes back. I've tried cleaning connectors and at first that seemed to modify, but not fix the behavior. When I do get it running the idle hunts around a lot and tach needle fluctuates, more than the actual rpm changes I think.
TVS blower on GReddy manifold
EFI 1.2
2bular header
Nearly new injectors
Any ideas? Any chance iI can fix this on the road?
Must get to work (200 miles) by 5pm tomorrow. I'm probably going to see if Princeton Lotus can pick it up tomorrow, but if I can get a semi-fix on it and limp up to Princeton, all the better.
Your advice appreciated.
EFI 1.2
2bular header
